Hello all - Got a 98 Shee and took her out for the first time over the weekend. Has larger Carbs (Keihein PWK), boost bottle, and a few more mods. Starts up fine and idles good, but would bog down going into first unless I feathered it. Once going, runs fine. Rode the dunes a bit and headed back to the truck, put her in neutral and when I tried t put her back in gear, she was stuck in neutral. Shut her off and shifted through the gears, wouldn't grab any gear and just stayed in neutral. Tore the side cover off, took clutch basket off, checked all components, all looked good. Shifted through the gears and just wouldn't catch and rear tires just spun as if in neutral. Was thinking tranny was trashed so started to button the Shee back up and realized the pancake bearing was the culprit. I think it rattled loose when I was riding, throwing the clutch all out of wack. I tightened it enough for the clutch to work and buttoned her back up. filled her up with some ATF type F and kicked her over. Let her warm up a bit and shifted her into first, started to roll forward and I shifted into second. Almost feels like when I shift into second, it kicks into neutral for 2 seconds and has no power, but then will start to go in that gear. Does the same for all other gears. Any ideas? I am going to mess with the pancake bearing again tonight to see if it helps, but it just seems like it takes time before it "catches" gear. I don't think my forks or anything are bent, ne metal shavings or anything were in the fluids. With the bogging, I am going to inspect for air leaks but I really don't think there are any. Ill mess with idle and air screws tonight on the carbs. I am running 32:1 mix. Thanks for any info you guys may provide.
