TIFELIXJR
    2000 Yamaha Banshee
TIFELIXJR's Achievements
  1. Let me know, really interested
  2. Can you message me at my number? 9094466230
  3. If still available can you send pics? 9094466230
  4. Ok thank you, do you think that my jetting might have something to do on why I do not need to choke it to start it up when it’s cold
  5. If you guys can help out that would be greatly appreciated
  6. Hey guys, I’m new here and was wondering if you guys can help out with my jetting. I have a 64.50 Wiseco top end, fmf fatty pipes, and the toomey 2:1 air box delete. For the hotter weather (80-100) I was always running 25 pilots and 270 mains with the air screw 2 1/2 turns out , and never had an issue, but now the weather in my area is anywhere from 40- 70 degrees Fahrenheit. My elevation is 1500.
  7. Sorry for all the errors, i meant to put it doesn’t run on both but when you start getting on the top end it starts waking up
  8. Well it’s because i read on one forum that it could’ve been the reeds ignorance it’s kny running at the starts waking up on top
  9. Ok, everything in the carbs Ian on the correct side, and everything was done right, how do i know which bowl goes on which carb to make sure i didn’t do it wrong, also i was gonna do 27.5, but i went to chaparral and they only had one sadly so i have to find the other now or order one online. And the reason I thought it could’ve been the reeds, is because once it hits the power band is when it’s running properly on both sides
  10. Well here is the, i don’t know how to actually check the reeds, but before I had this issue, by carbs were never synced, it stared having the issue after I let it sit for a while. And my jetting is 270 mains and 30 pilot, but gonna go 25 pilots cause it’s running kind of rich. Elevation is 1500 feet, and i have fmf gold Series with the toomey 2:1 air box delete
  11. Yes I have
  12. Hey guys, first post here, and I was wondering what the symptoms of a bad reed are? I just rebuilt my motor and it only runs on the right side, but if I start giving it some throttle, it starts running on both. I had read that it can happened with a bad reed, but I’m just not too sure and want to confirm before I start spending money on a new set. I’ve tried putting new pilots in it, didn’t help, I’ve tried 3 different coils, didn’t help, and I’ve swapped the plug caps from one side to the other and the problem didn’t follow. (New plugs btw)
