klh2000
Everything posted by klh2000
  1. If you still have them, do you have any pictures?
  2. I'd also consider PTR hi revs. The DMC or PTR high rev is my ideal choice Sent from my ONE A2005 using Tapatalk
  3. Looking to trade for some different pipes, previous owner had them installed, just doesn't fit my riding style. Would consider dmc 916 or aliens, a nice set of fmfs or bills plus money, May sell for the right offer. They look to have had the mounting tabs welded back on at some point, but plating is all in good shape. Sent from my ONE A2005 using Tapatalk
  4. Sorry it took so long, but other things git in the way. Just did a leak down test, held 7psi for over 10 minutes. I am going to switch to FMF fatty header pipes just to try them out since I have a set. I want a little more top end power, but not sure how much I'll be able to get with a single carb. I have an eej needle if I remember correctly Sent from my ONE A2005 using Tapatalk
  5. I ride year round in NY. The previous owner raced it years ago. It was set up for 110 octane when I got it. I backed the timing off and put in the 21cc domes Sent from my ONE A2005 using Tapatalk
  6. I won't be able to work on it this week but I guess I'll do a leak down test. It does run perfect though. Idle doesn't creep or anything like there is a leak Sent from my ONE A2005 using Tapatalk
  7. Middle position and not sure what needle, I'd have to check. With a 198 the plugs were white.@ZillaFreak Sent from my ONE A2005 using Tapatalk
  8. Just picked up my first banshee. Has lots of aftermarket stuff, but I am questioning the jetting. It has: Trinity 2-1 intake 35mm pwk Paul Turner mid pipes Trail porting by redline 21cc domes. I am 300ft above sea level, currently a out 20 degrees f out. I have a 55 pilot, which seems about right, but I am up to a 238 main, which seems way higher than what most people run. It runs fine, but it almost seems like it should go richer because there is no smoke. It came with a 198 main, and ran exactly the same on that. I am just worried about running too lean. Sent from my ONE A2005 using Tapatalk
