HavasuBanshee
Everything posted by HavasuBanshee
  1. Damn that sucks man does your back feel better if you go more in the fetal position/sitting, or does it feel better standing/ on your stomach with back arched. Also do you have tingling pain into your butt/down your leg?
  2. Haha I can offer free advice for anyone with physical issues. I work in Physical Therapy so I know how to fix bodies just gotta get better at fixing my Banshee haha
  3. Lol maybe it still needs some tuning but it's running so much better now and actually sounds like a banshee and poppy and not sluggish anymore
  4. Yeah I'm glad I learned how to do the carbs a bit now and had some trouble synching them yesterday and actually getting it to idle without dieing yesterday but I managed to get it going and I'm taking it in the desert today.
  5. Sucks not knowing how to work on this stuff. At least it's running better and I'm learning
  6. Running a lot better now after all this and stopped leaking gas from carbs. Left 25 pilot in. Might have to upload a video to see if you guys think it sounds good.
  7. Dang. Seems very touchy. 30 too high, 25 too low
  8. Should I put the 30 back in or just try the 25 with 300 main. Don't have 27.5
  9. I thought you said 30 was too big
  10. Thanks for the help everyone I swapped the 30 pilots for 25 pilots and kept the 300 mains. Replaced both needles and needle seats with new ones. Wish me luck for synchronizing. I have air screws set 2 turns out from fully seated.
  11. There it is thank you! Would have been wondering where it goes haha
  12. Thank you. They come with an O ring and have no idea where it goes because I never took one off mine. They're lmedium to small black o rings
  13. Thanks for the tips. I'm going to local shop on my lunch hour to see if they have the individual parts but I called and they have banshee rebuild kits so I may just pick those up instead to ensure everything is fresh.
  14. Thanks for the tips I'll check the needle tip and I'll remember the jamb nut when I get to synching etc.... Now I am confused as to why the heck it had 2 o rings on the one on choke side but only 1 ring on other. Comparing the 2 sides rings, the Right side ring actually looks a bit flat. What do you think? :I just may replace both of them if my local place has the parts.
  15. This is the one from Choke side. It has 2 rings on it and was very hard to get out obviously I messed it up pulling it out scratching it. So is the other missing an o ring or? https://ibb.co/LSr6fyH
  16. I have a 300 main and 30 pilot. This stuff looks really clean. Does this look ok? https://ibb.co/WpJ72Ck
  17. Ok thank you. When I take them apart I'll of course check the condition of everything and come back here with any questions. Might take me a while as it's my first time taking a carb apart x2.
  18. Ok I also need to consider where to set my clip at because as of right it it does bog a little bit at start of throttle in 1st gear. Makes it sound like crap putting around slowly in 1st gear. Mid throttle it starts to pick up.
  19. What main jet and pilot jet sizes do you recommend in the case I may have to buy a rebuild kit if the gaskets and o rings are shot.
  20. Ok I'm going to start it tonight. It definitely is annoying just leaving it to mystery so I'll take them off after work. Thanks for the help by the way
  21. Since buying the shee I haven't checked the carbs but previous owner didn't know squat but said his mechanic had it dialed in for my area. If I can't get it dialed it I'm going to take off and clean/check everything in carbs and adjust floats as well because they overflow unless I run bowls dry before turning the bike off.
  22. Does my right carb look correct? I circled some areas that look like open holes. Also. If I turn those idle screws counter clockwise it becomes too loose and the vibration will rotate them. I'm getting my carb synchronizing tool today so any advice is good. I'll be using south Texas banshees video on synch. https://ibb.co/hZ3yf92
  23. I went roughly 2 to 2.5 turns out from fully seated and it sounded a lot better. I plan to take it on a test run. Still need to check synch which will take 10 seconds tomorrow.
  24. Ok I'll work on this stuff. I originally only tried leaning out than rich so I'll try that after addressing the synch and start from fully seated
