My 2001 banshee started to not run right all of a sudden and started to get boggy/power loss during my last ride, i looked back and seen excessive white smoke coming out of my right exhaust.
Here is what i have done so far but the issue still exists.
Motor is stock. I first changed the plugs.
Compression was 140psi each side with very little variance.
Thought i may have lost or been burning coolant, O rings on cool head were all good.
Rings were ok, Quite noticeably a more brownish colour to right side piston crown though.
Carbs are all good and synced, reeds are good.
I did a leak down test, i was expecting a bad pto side crank seal but i had good results, i put 6psi in and had over 5psi after 6 mins.
Gear oil level was good.
What should my next steps be or what are your thoughts.?
I have seen this similar issue online recently but never with any resolutions posted, i am not sure what to do now.
Appreciate your time.
