I've got a 2001 yamaha banshee having trans issues. I bought a clutch basket, inner clutch hub and idler gear. When I start it in neutral it makes a grinding noise as soon as I pull the clutch in it goes away I can shift through the gears while running with clutch pulled just fine as soon as I start to release the clutch it starts grinding again. also when I have it in gear and release the clutch it starts to take off like normal with no grinding. Just looking for help on what i should check. I did have everything apart while putting the clutch basket etc in. the clutches looked good everything went together like it should.
