joshpam8
Everything posted by joshpam8
  1. this was the feature race my arms got so worn out from fighting it in the turns and I couldn't carry my speed into the turns I'm the only banshee there I'm in second the whole race the leader is running a 250r frame with 426 dirt bike motor I can pull him on the straight but I can't carry it through the turn if the link doesn't work look up Douglas Bartlebaugh and look for ATV feature at thunder mountain speedway 6/15/18 Sent from my SM-G930V using Tapatalk
  2. Works flat track and tt front shocks don't toe is stock never really did any thing with camber and caster Sent from my SM-G930V using Tapatalk
  3. Well I took first in the heat and second in the feature but the quad wanted to push in the front real bad I run Hoosiers in the rear but I have razor tt in the front I think I'm gonna get a set of Hoosiers for the front Sent from my SM-G930V using Tapatalk
  4. Ok thanks I'll try it I race tomorrow so I'll let ya know Sent from my SM-G930V using Tapatalk
  5. 5 or 6 Sent from my SM-G930V using Tapatalk
  6. Just wondered how people set there sway bars up do u want more pressure on your inside rear to help into turn or outside rear or neutral Sent from my SM-G930V using Tapatalk
  7. Yea I sure don't have a few hundred bucks laying around nobody's perfect they need to man up and it's not like I sent them a nasty email they could at least email me back how do you run a business like that!! Sent from my SM-G930V using Tapatalk
  8. Yea me too Sent from my SM-G930V using Tapatalk
  9. Lol I'm hoping I don't have to but I will Sent from my SM-G930V using Tapatalk
  10. Well I had some motor work done by Duncan racing for my flat track banshee everything looked pretty good had tuning issues all last summer didn't finish 1 race. Left it set In my garage all winter cause I was so pissed off got it out for this season checked and double checked every thing idle hung for a couple seconds 1/8 to 1/4 throttle 1 cylinder would lean way out so made a few calls and sudco said are your carbs bored I said yes he said they might be over bored or off center bored they said hold it up to the light and see if you can see light so I did I see light put that carb on the other side and the issue followed so I called Duncan they said it isn't a issue put richer needle in it so I did no change so I bought 2 new 35mm keihin carbs put them on runs like it should so I sent them an email no response Sent from my SM-G930V using Tapatalk
  11. Yea might have to lol Sent from my SM-G930V using Tapatalk
  12. Duncan sent it with a cgk Sent from my SM-G930V using Tapatalk
  13. Yea I will I just ordered new 35mm today if it fixes the problem I'll be calling him back he told me to put a richer needle in it Sent from my SM-G930V using Tapatalk
  14. Yea it leans out just into the throttle and takes a few seconds to idle down only that carb though my quad has the 403 eliminator kit with shearer pipes 5mm billet crank v force 4 reeds dual 35mm carbs bored to 36.3 k&n filters 165 main 55 pilot air screw 3/4 turn out Sent from my SM-G930V using Tapatalk
  15. Called duncan today and emailed them the pic they said it shouldn't be an issue well it's giving me issues something is fucked up with that carb Sent from my SM-G930V using Tapatalk
  16. Thanks I haven't had any issues yet with the sensors but I'll try something once Sent from my SM-G930V using Tapatalk
  17. I agree Sent from my SM-G930V using Tapatalk
  18. I agree but I only flat track mine and they make this adapter for 2 strokes to help them last longer Sent from my SM-G930V using Tapatalk
  19. Summit racing it's an innovative dual wideband a/f meter Sent from my SM-G930V using Tapatalk
  20. Yea it gives me my air fuel mixture I still look at my plugs though but it does help with tuning and while I'm racing I can see what it's doing if it goes lean I can shut it down without melting a piston Sent from my SM-G930V using Tapatalk
  21. Built a battery box for it and put an air fuel meter on it seems to work ok Sent from my SM-G930V using Tapatalk
  22. Yea I have had nothing but problems they won't stand behind there work either they wouldn't even work with me at all I was running a 165 main and 55 pilot clip in the middle so I know the jetting was ok Sent from my SM-G930V using Tapatalk
  23. I only flat track it I don't ride it around it sits in the garage when not racing Sent from my SM-G930V using Tapatalk
  24. Yea I'm gonna call them tomorrow they told me I need to run all there parts reed exhaust intake boost bottle. They fucked my fly wheele up when they lightened to. They said I melted the piston cause of a weak stator but I have a new stator cdi coil and plug caps. Had to buy a new fly wheele cause when you shook it it sounded like a bunch of sand in it Sent from my SM-G930V using Tapatalk
  25. Same deal with the other slide Sent from my SM-G930V using Tapatalk
