Paulg83
Paulg83's Achievements
  1. I rewired the bike. Checked everything 15 times. Then I went to check gap on pick up coil. Annnnnnd the flywheel falls off. Keyway was sheered. And loose. Replaced key. Lock tight the nut and starts first kick. Thanks for the help guys.
  2. So I picked up a banshee. Yes I have owned several. It’s blue has pro c exhaust and new tires. Guy said he was ripping it and it die. The coil pack had a free air ground splice. What more do I need to say........should I require the whole bike or spend 140 for a harness to start? How many of you have had luck wiring on your own. I’m an electrician by trad I have 14/16 wire coming out my ass but will standard wire take this beating over time? Oh an I can’t find a stock wiring diagram to include the keyed assembly what do I tie to the shut off? I don’t need my kid trying to run it when I’m not home and hit a tree.......
