B-shop164
Everything posted by B-shop164
  1. Only 400 feet
  2. Yes i have a good tester and the domes is suposed to have the good elevation
  3. Cilinder kit cheetah cub 68/58 brand new and piston from fast clean ports /domes 20cc/10 /052 and the squish is .050 Brand new gauge and another gauge said 130 psi to ,throtle wide open and 20 kick and over .. the two side is exacly the sames compresion and all seal and all around is brand new !
  4. Hi, i have 20 cc BB race fuel domes from f.a.s.t in a cheetah cub and i have only 130 psi on each side? I chek with two new gauge and the same result ? Whats the prob ? Domes or leak?? Brand new motor fresh rebuild
  5. Ti zizouneeee 🙊
  6. Hi , it is normal when i chek my spark plug after 1 days no runing My plug are wet ? Its is gaz ( race fuel ) or coolant? The two side are wet and i completly rebuild the motor and put new O-ring in my cool head !
  7. It is a must to do a « porting » on a cub ? Or when i buy it « cleanport » its okays? .. setup for oval racing for best result
  8. Yes, i have all information aboute my engin , but no formul to calculate
  9. Yeah,!
  10. How can i calculate the good octane my engine need ? Its is possible to calculate ?
  11. Thank you sir
  12. Bad issu for me he ship me the wrong machined domes 2 times and after no issu to Contact with him
  13. First im testing with .062 solder but he dont touch , after im taking 3mm solder and the squish are done at .078. And its BPRACINGatv.com..
  14. Yeah im 100% sure i have cometic .020 base gasket. And its a oem cilinder ... its to much cut i think lol .078 🤦🏽‍♂️
  15. I have buy some 21 domes suposed to be cut and machined for +4 stroker crank and 19 cc but it test the squish and he have .078 ... and 160 psi i think he have probleme with the squish? I have .020 base gasket . Its the second set of dome we cut for me and the last have de same .
  16. Yes, i will change them
  17. Oh shit , srry its very not expensive !! I will change them lol
  18. Did you always change seal when you open your bottom case ? I have open my base and the seal look good! Can i reinstall them?
  19. Hello, i have a +4mm stroker and cool head 19 cc machined for 4mm stroker ! Whats gasket size i need for the cilinder ? .020? ( stock cilinder)
  20. And rockets pipe it is good? Or cpi and shearer are beter
  21. Need more hp and torq
  22. Yeah i think its shorter than 1/2 mile... im confusing about my choice of pipe .. y have t5 on it but i buy a new set off better pipe
