Bambi
Everything posted by Bambi
  1. Slides are in the correct carb, coil wires are good too. Just adjusted the floats. Going to try it out now
  2. Checked the ground, took a ride and still acting like the right cylinder is starving for fuel. Could it be float/needle related? I remember I had problems getting the slide in that carb because of the needle, it wouldn't get in the hole, like my needle was a little bent ... could that be my prob? Also switched the coil wires and still doing the same on the right carb. I might also try swapping the carbs tomorrow.
  3. It was running fine before, but i'm definitely going to check the ground.
  4. I really meant 380 jets lol, the stock head was modified for domes, and to hold more prestone. My pilots a 27.5 i think. But the quad was running well before I took the engine out to paint the frame... i'm going to open the carbs up to see if the floats are getting stuck. Last time i did a compression test it was 120 psi on both. I cut my coil wires to make sure connections were good,changed plugs. I'm gonna try plug chop too.
  5. when i go wot for 10-15 sec,then release the throttle, it starts sputtering on only one cylinder, sounds like it doesn't get gas or has too much...a lot of times it happens when i'm going uphill. When i stop for 5-6 sec then get back on it, it runs fine again. Stock air intake with no lid, t5 pipes, porting and stock shaved head for more prestone and domes. 380 main jets, i went up 20 for winter. I run 35:1 mix. I cleaned the carbs and sync them
