Timmy s
Timmy s's Achievements
  1. i just took a hose and and sprayed down the plastics and the case i made sure not to get any water in the air filter
  2. i took my shee down to the sand dunes last weekend and it ran perfect all weekend but when i got back i cleaned it down real good, now it wont run right, it wont idle, it Boggs down when i give it gas, and it misfires. can somebody please give some advise of what it could be
  3. its a brand new lock washer, im wondering if runnin hard and fast at waynoka all day is what did it
  4. The lock washer was folded against the nut but i am not sure if it was tourqed to spec I just hammered it down with my impact
  5. the center nut that holds the clutch together backed out even though i had the tab on the washer folded up and it was torqued down. does anyone know what could have caused it so that it doesn't happen again
  6. it just gave the carbs a real good cleaning and were all good now
  7. me and my buddys are heading down there on the 23rd, me and three others on banshees and probably some side by sides and raptors
  8. Whats the best way to check for an air leak
  9. whenever i rev my banshee during idle it stays reved up and wont come back down
  10. the carbs are getting fuel i can open the screw at the bottom of the bowls and fuel pours out, and also i can take the fuel line off and it pours out gas
  11. i just rebuilt my motor on my shee it has spark and 165 psi compression but its not getting fuel into the cylinders i have to pour gas into the carb manually to get it to fire up and run for a few seconds, does anyone know what the problem could be
  12. i just bought a banshee with bad compression for real cheap, and once i cracked it open it turns out one of the pistons was blown. i already have new pistons and bored the cylinders but i was wondering if i could still use the crank, i brought it to a shop and they replaced the outer bearings and pressure cleaned the center bearings but could not replace them due to the crank being welded, the guy said hes seen crank in the same condition last years and hes seen them last days, i was wondering if i would be a horrible idea to run the crank or if it would last.
