Lukewarner99
    2002 Yamaha Banshee
Recent Profile Visitors
Lukewarner99's Achievements
  1. I ohm tested it and it tested at 18.4 ohms so that’s in spec but it still smokes when I run it and all the coating around the poles are burnt why did it burn up when i put a new one in I don’t want the same thing to happen
  2. I think whoever put it together last only put 2 bolts in that connected the stator to the backing plate because the didn’t line up the correct holes could this be the problem?
  3. Ok so i took the flywheel and stator off and it’s definetly burned up its all black and brown is there a reasOn why or does that just happen over time I lived at the wores I don’t see anything wrong so what could have caused this?
  4. Yep it was that black wire with the white stripe
  5. So you don’t think my stators shorting or something it smells burnt and Are there any common places where wires break in the harness or how should I start look for the kill switch wire there is a wire from the harness that’s black with a white stripe that isn’t hooked up to the black with a white stripe coming off the switches
  6. Well I don’t know if it’s rubbing on something I know the flywheel is what spins around it but when I look through the little holes In the flywheel parts of the stator look melted almost have no clue why it’s smoking
  7. Hey guys I’m putting together a 2002 Yamaha Banshee and when I start it up and it runs my stator starts smoking what could be wrong with it and how could I fix it and also my key switch is missing and I don’t know if it been bypassed or not but my kill switch doesn’t work eother
