Eric2057
Recent Profile Visitors
Eric2057's Achievements
  1. I’m running 19cc domes. Talked to Shawn at top dog before he rebuilt the bike and he said that’s perfect for what domes you’re running
  2. I installed my Alba’s and everything went smooth. But when it came time to mess with the camber I ran into a slight problem. I noticed that once I got the wheels set up perfect that my left upper ball joint is screwed out farther than my right side. I’ve taken measurements and everything lines up perfect with the other side. I’m stumped. Any help would be appreciated!
  3. So I pulled my carbs off today to change float bowl gasket, float needle and adjust float heights. Got that all done and installed the carbs back onto the bike. It started up and runs good but for some odd reason I've got more smoke coming out of my left pipe than my right? Any help would be much appreciated!
  4. Alright sweet thanks!
  5. Don't run 50/50 racefuel? And whys that? I've ran 50/50 in my bike ever since I've had it
  6. So I have a slight leak on my bike coming from my clutch cover gasket. I have a big weekend ahead of me of riding and will just fill up as it gets low( drips probably 10 drops at the max when parked) I'm wondering if I can just look threw my lockup clutch cover and tell my tranny level threw that? Or do I need to look at my dipstick? I know where it should sit by looking at the lockup cover so will just fill up when it gets past that point. Sorry if that didn't make any sense I can try and clarify if need be.
  7. I run 50/50 racefuel with Yamahalube but changing to Klotz. What's the difference between the Klotz r50 and the super techniplate? What should i run?
  8. I run 50/50 racefuel in my banshee and want to change to Klotz. What Klotz do I run Klotz r50 or that super techniplate stuff?
  9. Okay thanks for the reply! My bike has a lockout cover on it and already has Allen heads for the bolts on the cover.
  10. I'm going to be changing my clutch cover gasket in a few days. I'm going to drain out all the tranny fluid but I'm wondering about the coolant? Do I need to drain it out of the bike and motor so I can pull the side cover off? Basically need a step by step on how to change the gasket. Thanks in advance!
