BirdEyes
Everything posted by BirdEyes
  1. yeah I just changed the cable. Did not open the cover. When I get time I will check to see if it can be adjusted to fix the issue. If not it sounds like I will need to open up the cover.
  2. Great! Just what I wanted... more on my plate. I saw that process in the service manual. I was hoping I wouldn't have to do any of that since I just swapped out cables. I might get into this over the weekend. Thanks for everyone's help!
  3. There wasn't any ball when I changed out the old one. 99% sure it is the correct cable. I laid them side by side after I pulled off the old one. They looked the same & appeared to be the same length. I will check the adjustment as soon as I get some time.
  4. It is about mid point at the perch. I try to adjust there some after work to see if that helps.
  5. Yeah it doesn't spring back.
  6. I had to replace my clutch cable due to the old one being badly frayed. The new one works great but now I have no pressure on the handle. The spring at the end of the cable appears to be ok. This is the spring that should put tension on the clutch handle correct?
