Bansheejm
    POS
Recent Profile Visitors
Bansheejm's Achievements
  1. https://www.flickr.com/photos/157996045@N05/shares/o73118
  2. is it right or wrong
  3. I just bought some used lonestar arms for the banshee ,well I hope they are lol . When installing them I noticed either arm can on any side .. I know this might be a dumb question but how can I tell which is left and right ?I'll try and load up a pic of them installed hopefully they ain't backwards .
  4. well I had bought the o ring kit and studs with the acorn nuts kit that goes with this head but when I took off head I found that all head studs were not straight or bolted in all the way. So I took off the studs and found the middle two stripped and the rest where a mess I guess who ever had this bike before re threaded the holes but did a messed up job doing it some studs weren't even straight. I tried fixing the holes by helicoiling them but the holes where just to messed up to fix so i just ordered new jugs instead.
  5. I never checked them I just bought the quad like 2 weeks ago thinking it was good but I was wrong all these little things and problems are coming out who ever put aftermarket parts did a shitty job
  6. so yesterday was the first time I took my banshee to the sand dunes 10 mins into riding and it started smoking bad from one side I noticed my coolant was low too so I added coolant and i can hear like water sipping thru the head..... I saw all the bolts had came loose on head , and it has one of those cool heads ..Why did it come loose am I suppose to add some of that thread lock ....i just bought this quad and it has been a headache
  7. Found problem it was the pin it was pushed in gave it a few taps and out it came out again
  8. I will try to upload a video of what's happening when I get home n yes that's what it seems like the slide is doing its binding instead of going up and down straight it's turning as for tors it has been deleted then...there's no wires on top of these caps
  9. I just bought a banshee with some problems that I'm trying to figure out . Ok so i got my banshee back yesterday from a shop I had taken it so they can clean and rebuild carbs so I get back and take it for a ride then I get on it and all of a sudden it revs it self high and stays like that so I pulled off one of the filters and saw that the left carb slider stayed up. So I took off cap and check it and reassembled it back and it landed straight down again but then noticed when I hit the throttle the slides go up and when letting go the left side slide kinda twist out of its way where it suppose to land again which is a screw and stays up if I turn it with my finger if lands back where it suppose go so what I wanted to know y is this happening is it a throttle wire issue where slide grabs on or is something not put on right I've been looking searching around looking at different info and from my understanding this quad already has the tors delete
