njdevil
Everything posted by njdevil
  1. I am hoping I can just re-ring them. I will be doing some measurements this weekend, hopefully. Never really played around with a 2-stoke to much. I am more of a small block Ford guy. Can't be that difficult same basic idea, smooth and straight.
  2. Yes, I am aware of that, at the time i was running out of ideas and sanity. Couldn't figure out why it would only pull fuel at WOT.
  3. For starters, 99 Shee mostly stock other than K&N filter , gearing change and FMF fatty. Owned for about 8 yrs. basically just change the oil plugs and keep it clean. Run at a 40:1 ratio. I just rebuilt my carbs, forgot the choke tube (first time mistake), took me a while to figure that out. Wouldn't start but would run if I shot a little startin fluid in carbs and held a WOT. Does that sound right? If I put the tube back on should it run normal? Assuming everything is tuned in correctly. Also compression around 90psi in both heads, Do you think that is time for a rebuild or can I just replace the rings? Walls look and feel pretty clean, never really beat on it as far a Banshee goes.... Thank You for any thoughts.
