Bottlefed07
Bottlefed07's Achievements
  1. Is there any better Pistons out there then the prolite just looking to make the most power dosnt matter if I have to rebuild more offten
  2. So guys I finally pulled my motor apart tonight and it has a prolite set of Pistons in it I'll also post some pics of the cylinders here in a bit
  3. Stock stroke long rod sorry about that piston
  4. Soooo dose anybody no what kind of piston I should run size wise I seen somebody said long rode short stroke so it would be a 65.5 mm x 5t4mm long rod piston or dose the stroke matter with this one
  5. Soooo dose anybody no what kind of piston I should run size wise I seen somebody said long rode short stroke so it would be a 65.5 mm x 54mm long rod piston or dose the stroke matter with this one
  6. Yea it's the fastest 365 I've ever seen before and it just dosnt have the power it use to that's y I wanna rebuild only has 135 psi a hole and when I got it it ran 180 a hole and I only use it for dirt drag
  7. Here is is this is y it dosnt make sense to me hey measured for and it came to 54 mm
  8. Shows that it's at 54mm
  9. I'm pretty sure but what's the best way to measure stroke with plug out
  10. Hey guys I'm trying to rebuild my quad but I'm kinda confused on what Pistons to order somebody else had the motor built before I got it but buy what I know without measuring bore and stroke it's a 65.5mm bore and a 54mm stroke but it has a spacer under the cylinders so my thought is it would be a 58mm right but I'm not for sure
