-Tors eliminated
- Key switch bypassed
- Kill switch unplugged
- Cleaned stator plates although I'm not sure they are the ground but anyway I cleaned them.
- Used in line tester for spark
- pick up gap tested
I do appreciate the help but I am no newbie to this, I'm a pretty good mechanic that's why I said it's not fuel or compression or reeds, the thing honestly will kick over and spark then 5 mins later you can kick and kick and kick and it will not spark.
Since I am able to push start it I did the following, used 2 stators with different plates and coils, runs the same, used 2 flywheels runs the same, 2 coils runs the same, 2 wiring harnesses runs the same, original cdi box will not run, used oem box will push start, so I think my question is will a CDI box cause this, I was under the impression that they either work or they don't but I also know that they use an internal capacitor to store energy to send a pulse to the coil, is it possible there is an internal fault causing this condition?
