Dirt_Works
Everything posted by Dirt_Works
  1. Forgot to mention that the tors have been deleted I did try a new oem ignition coil and new oem plugs caps and the carbs have been synced i adjusted the pickup coil gap i have ot written down at home what i adjusted it to and the ignition timing is at 0 will have to get hold of a leak down tester and try that that is.really the only thing that is left I suppose
  2. Hey guys I have a 2000 banshee I bought it in boxes. I finally got it put together and started idles and revs out with no load flawlessly how ever when I put it under load it spits sputters and just kinda chugs around. I did have it running pretty good at. First but it just wasn't quite rite it would hit power in 1-3but would go through the rpm instantly and have to shift right away shift into 4th and it would just big down so I tore the carbs apart and noticed both slide needles were bent I replaced those with OEM and installed in the middle position. I also replaced the reeds with OEM I also found the tip on the choke plunger broke off so I replaced that with a new OEM one as well I have jetted from one end to the other starting at 300 on the main all then way to 400 and also changed the pilots from 27- 35 with no avail I noticed when I replaced the choke plunger is when it got to the worst I have 137 compression on one cylinder and 138 on the other any thought I have not checked crankshaft seals yet at I don't have a leak down tester The quad has what I believe is the Athena 392 kit and before the bashing starts I read everybody's opinion on the Athena kit Stock bottom end Stock carbs Stock air box no lid k&n filter Procircut pipes No clue on silencers OEM replacemen . Jet needle OEm replacement reeds If any one has any thoughts let me Mr know please
  3. it wont let me upload ive tried but it says it is to big to upload it is only a single picture i have no clue how to change the file size so that it will up load
  4. thanks for they help guys athena also just got back to me with the same response and a the kit being garbage i know they are kruddy but it came with the quad so i am going to run these while i save up for a 421 cub
  5. so im installing a 392 big bore kit by athena on my 2001 banshee and i am beyond confused rite now. i am installing the rings and the 2 normal rings marked 2 and 2 r fit perfectly but i have a another ring in the bag that is in octagon shape and i cannot figure out where is should be installed has any body ever installed one of these kits that can help me out on this
