Silversheee
Silversheee's Achievements
  1. Well I synced the carbs. Went up too a 52 pilot, turned the air screws out a half, moved the needle down and it still has a pretty bad bog in low end revs, the top end is still good. Could something else affect this other than the carbs?
  2. So too start off I'm pretty new to banshees. I recently changed motors I bought a 421 ported serval and I just can't really figure it out so I need your guys expect opinions. It idles fine but it will bog/hesitate when I give 0 to about 3/4 but at full throttle it takes off. I currently have SLP pipes 28mm pwk carbs jets are (170 Mains)(48 pilots)(Stock needle jjh on 2nd Clip) Air screw 1.5 turns Elevation is 800ft Compression is about 150 and 145
