sander.reijenga.
sander.reijenga.'s Achievements
  1. Haha it is a wiseco crank Verstuurd vanaf mijn SM-G900F met Tapatalk
  2. Thanks, ok then the thicker spacerplate is maybe the best idea. I have had my cilinders done with new matching pistons, so if i buy the 795 pistons i have no use for these. So the following question. Return the stroker long rod and change for stroker short rod. Or make a 7mm plate? And keep the long rod Verstuurd vanaf mijn SM-G900F met Tapatalk
  3. I needed a new crankshaft and found one at a friends place, it was there at his garage for some time but never used. He said it was a 4mm stroker short rod and i trusted that so i ordered a spacerplate because porting is not really an option in the netherlands,and if they can it is to expensive. After i receive the spacerplate i put my new topend together and when i turned the flywheel my piston rises 5mm above cilinder deck so the upper pistonring came out. So i guess this is a long rod crank. Ok so now i want to know what options i have with this crank because i can return it no problem and look for or a stock crank or 4mm shortrod. But is there some nice solution to make this work? Thanks in advance Verstuurd vanaf mijn SM-G900F met Tapatalk
  4. I run in same carbs at sealevel and almost same mods as you Main 155 Pilot 50 Needle jjh middle clip Verstuurd vanaf mijn SM-G900F met Tapatalk
  5. Jjk Verstuurd vanaf mijn SM-G900F met Tapatalk
  6. Ok so my needle is the problem Verstuurd vanaf mijn SM-G900F met Tapatalk
  7. Hello I need a jetting start for the next setup. I switched from stock carbs to 28mm pwk keihin 65mm bore Fmf fatties V force 4 28mm pkw Timing at +4 Sealevel. Mix 32:1 Can somebody point out a safe starting setup for the keihins so i can start plug chop. In stock carbs i was jetted 320 main needle stock and middle 27,5 pilot and 1.5 turns on airscrew Thanks in advance Verstuurd vanaf mijn SM-G900F met Tapatalk
  8. Yes it belongs with second ring. My friend has this set up and we were also confused but then we found a very small piece of paper in the box which explained all. The only problem is......we lost the paper otherwise i would upload a foto on this Verstuurd vanaf mijn SM-G900F met Tapatalk
  9. It has to be under the second ring Verstuurd vanaf mijn SM-G900F met Tapatalk
