DESTRUCTIVE
Everything posted by DESTRUCTIVE
  1. Lol ok cool do you recommend anyone or can you point me in the right direction
  2. No I just found out about this forum
  3. Ok I just bought it from eBay so maybe that's why. Is there a good place to get a stator for my bike
  4. Hoppedupandcutdown, I have have the black and yellow from the stator unplugged right now. I checked AC&DC at the black and yellow wires and nothing. What to you mean by unplugged
  5. Ya it's for AC I tried 3 different meters also with bike running
  6. With bike off if I get .2-.3
  7. Where is the ground on the stator at and what do you mean o/L
  8. I tested the stator at the bullet connectors, and no voltage
  9. The one I bought was from ebay not sure if that's why it's not working or if something else could be wrong. Does the flywheel have anything to do with the lights while the bike is running
  10. Ok thanks for your info I will get a new stator any place you recommend. The fly wheel doesn't have anything to do with making voltage while the bike is running does it. I even checked for voltage at the wires for the brake light while bike is running and nothing
  11. Keno I have no voltage from the regulator and the ground is tight
  12. I have no voltage at the yellow and black wires coming from the stator with the bike running, with a DMM I have tried 3 DMM just to make sure it wasn't a DMM. Is it possible that the stator I bought is bad
  13. My brake light bulb is good my fronts I have disconnected since they broke when I crashed a while ago. But I have no voltage going to any of lights. Is there a way to test the voltage regulator
  14. My lights were not working so I thought I had a bad stator so I replaced it installed new one and I have no voltage to my lights still. Wires from stator on the bike right now(new stator) Yellow to Black from stator I have 0.2-0.3 White/red to white/green I have 117 Green to Red I have 13.9-14.4 Not sure what else to check made sure all grounds are good and even check to make sure the flywheel is grounding good. Any would be great thanks
