dsnellgrove241
Everything posted by dsnellgrove241
  1. Okay this is where I am now got the sputtering and popping to stop no leaks but it is still backfiring and barely smoking out of one side and has absolutely no power I can't even make it up my driveway Sent from my SM-G928T using Tapatalk
  2. I'm going go back through clean all my Jets again thinking maybe a grain of sand might have got clogged in one of the pilots if this does not work I will try the leak down thank you guys for your help Sent from my SM-G928T using Tapatalk
  3. Put brand new plugs in it also the only thing I really changed besides the plugs was I went from 27.5 Pilots to 30's I am tearing it all down at the moment had a couple of buddies I ride with that also have Banshees and they said it sounds like a clogged pilot to them that would cause all these problems Sent from my SM-G928T using Tapatalk
  4. Oh and I forgot when you give it gas it has like no power barely moves Sent from my SM-G928T using Tapatalk
  5. Banshee was running fine went riding in the sand... went to ride again and when I started it the idle will go up and down and it was making weird popping noise almost like popcorn would backfire a couple of times and then die I did notice there was a little bit of sand in my carbs checked all the boots nothing was cracked or torn filter was still wet so I clean the carbs all out cleaned all the jets and it still doing this Thanks any help will be appreciated Sent from my SM-G928T using Tapatalk
  6. Damn I feel good about the way mine looks but fuk I I'm not sure I'd put that f***** in the dirt at all it's a beautiful bike bro Sent from my SM-G928T using Tapatalk
  7. Sent from my SM-G928T using Tapatalk
  8. Sent from my SM-G928T using Tapatalk
  9. And we are averaging about 18 to 30 degrees here in Chicago Sent from my SM-G928T using Tapatalk
  10. I had this same problem with the cold air I had to go up in jets to 310 mains and 27.5 pilots runs like a champ Sent from my SM-G928T using Tapatalk
  11. Nice I'm running lid 10 ports.. how is it with head and 20cc domes can't wait Sent from my SM-G928T using Tapatalk
  12. The guy I got it from had it all stock 200 main and 25 pilots with t5's already on it so I thought this would already be done until I open them up and found out what was in them Sent from my SM-G928T using Tapatalk
  13. Just t5 pipes ,Boyesen dual stage reeds atm will be adding pro design cool head and 20cc domes in a couple weeks Sent from my SM-G928T using Tapatalk
  14. Sup guys newer to the shee world .. I recently changed my mains out and put 310's in due to it being so cold .would it be better to run 27.5 pilots or 30's Sent from my SM-G928T using Tapatalk
  15. I cut the plug for the parking brake located by my clutch lever since I previously removed the parking brake ..and this fixed all bogging issues I had when I would give it gas. I did not have to mess with the tors brain at all. Just had to separate the two wires and seal them so there's no chance of them touching and shorting something out ... Hopefully this will help someone this problem puzzled me for days Sent from my SM-G928T using Tapatalk
  16. Thank u all again ....blows my mind the parking brake was causing all the problems Sent from my SM-G928T using Tapatalk
  17. Thank u Sent from my SM-G928T using Tapatalk
  18. So I have been looking around trying to figure out the issue with my banshee bogging when I give it gas But idles fine. And in a video someone had was clutch perch or t.o.r.s system something to do with parking brake or something do u guys have any info about this problem Sent from my SM-G928T using Tapatalk
  19. Got it started was a stuck plunger in right carb thank u all ...new issue it is idling perfect but when you go to give it gas it will not rev up kind of bogs down and it backfires every once in a while Sent from my SM-G928T using Tapatalk
  20. Thanks for the help I will check all of it Sent from my SM-G928T using Tapatalk
  21. Hey guys I bought this bike 2 years ago didn't really ride it much but the bike absolutely ran fantastic started up first kick every time I got into an accident was on the track and a guy on a dirt bike lost control and hit me at about 40 -50mph pretty much totaled my quad out put me in the hospital for a while but I rebuilt the whole bike everything ran vantastic same thing still started on first kick then I added some boyesen dual stage power reeds recently and everytime I kick it its leaking out of the overflow tubes and will not start even with the choke in it still floods out I did everything I was supposed to do as far as the reeds make sure the surface was clean everything was laying flat and nice I don't understand what I could have done wrong I'm new to banshees this is my first build Sent from my SM-G928T using Tapatalk
