Miloe07
Everything posted by Miloe07
  1. Would do 3300. Sent from my SM-G930V using Tapatalk
  2. Could do 3300 Sent from my SM-G930V using Tapatalk
  3. Interested? Sent from my SM-G930V using Tapatalk
  4. Sent from my SM-G930V using Tapatalk
  5. Can send pictures at request.
  6. FOR SALE 3800. 1999 Yamaha Banshee. Asking 3800. Located in Parker CO. NO Trades. Cash only. Willing to negotiate. It has new parts out the wazoo (bearings, lights, clutch, springs, shocks, handlebars, alba a-arms, 28mm pwk etc). It has FMF gold series pipes. List of everything done: Handle bars and grips. Speedo. Aluminum rad. Steering shaft bearings and seal. Led lights. Front bumper. Alba plus 2 complete front end. Shocks. Wheel bearings front. Nerf bars. Cleaned carbs. Exhaust springs and seals. Kick starter rebuild kit. Clutch basket pucks plus rebuild ring and screws. Clutch and springs. Clutch cable. Swing arm bushings rear shock bearings. Swing arm protector. Brake rotor, led brake licence plate running light. Rear grab bar with rack. Seat cover, rear tires and rims, axel bearings. Axel lock nut. New brake fluid. Fmf gold series pipes. Complete bolt kit stator and clutch cover 250 bolt kit. It's been bored to a 66mm piston (369) and has the long rod. Has 21cc domes currently but also comes with 13cc domes. I would be asking 3800 for it and will give all parts with it. Thanks
  7. Please text me pictures. I am interested. 9702152438. Thanks
  8. Will those work on my bike? I am only bored 0.080 over and stock stroke.
  9. Looking for sf/sb out of frame exhaust. Need to have silencer and preferably spark arrestor. If no spark arrestor a removable end cap so I can install one. Can be both out 1 side or 1 out each side. Please let me know what you have. I lI've in Denver colorado.
  10. Looking for sf/sb out of frame exhaust. Need to have silencer and preferably spark arrestor. If no spark arrestor a removable end cap so I can install one. Can be both out 1 side or 1 out each side. Please let me know what you have. I lI've in Denver colorado.
  11. Can the end caps on the Graydon pipes be removed to install a spark arrestor? And will they fit on a stock flange?
  12. Awesome. Stock crank. Will upgrade next rebuild to 4mil stroker.
  13. Is the stator still available?
  14. I wanted 15cc domes but they didn't make them
  15. No thanks. I went 16 to get compression as high as possible at 1 mile high. I also run at the dunes which are at 8k ft.
  16. Looking to buy OOF pipes for a banshee with stock stroke, 66mm pistons, cool head with 16cc domes, and 35mm mikunis. Pipes need to be able to be retrofitted for spark arrestors, but would prefer to already have them that way. Live in denver colorado. Thanks.
