new2the'shees
Everything posted by new2the'shees
I have replaced the needle valves no more leaky overflows.
Selling my excellent condition, freshly rebuilt 2002 Yamaha Banshee 392cc big bore. Only negative aspect of quad is 30% front tire tread left and 50% rear left, and just ordered two Factory Yamaha OEM needle valve assemblies from Motosport, will install upon arrival or can send to you if you want the quad before they arrive. A ton of money just went into this rebuild and this quad is FAST...I want an AWD turbo car so I am selling this to free up funds. I may trade for Eagle talon tsi or Mitsubishi Eclipse gsx clean. Parts with 3 hours of riding time: Athena 392cc. Big Bore kit with cylinders Hot Rods crank and complete bottom end rebuild kit Hinson clutch basket Tusk heavy duty clutch kit with springs MSR clutch lever Motion Pro clutch and throttle cable Extended A-Arms plus two inches wider and one inch forward Grips fat jetting 310's and 35's to keep it rich O-ring chain and both new sprockets stock gearing Pro Design Pro-Flow air filter kit with adapter and foam filter Other aftermarket parts include: FMF SST exhaust pipes with great shine FMF Powercore two silencers ITP Wheels Newer aftermarket chrome front brake calipers MSR clutch lever, and new cables. $3000 obo http://pittsburgh.craigslist.org/snw/5374746575.html
Only starts on lubed starting fluid...
new2the'shees replied to new2the'shees's topic in Banshee Repairs and Mods
Private message? Where could that have helped me here? I PM'ed many individuals on here to help me with the issue. -
Trickedcarbine liked it....You're just mad because you were one of the individuals who used the cop out. lol -
Thanks tricked. At least someone agrees that was a bit rediculous lol! -
Thanks to the individuals who were willing to discuss my carb problems. Shame on everyone else who used the compression and leakdown cop-out... -
\ Turns out, new bowl fixed cold start issue, but not lean left. Turns out lean left cylinder, was actually extremely rich right, as the main jet fell out of the right carb. Bumped up mains to 280's. She runs excellent.Went on a nice two hour ride the other day and she totally ripped and came back in one piece most importantly. -
Why leakdown when you have every single reason in the world to believe the carbs are the issue? Even motooutcastxxx agrees this is the culprit of most if not all of my issues here... -
Leakdowns are wasteful when you resurface and torque everything to spec as shown in my leakdown and comp test. I measure twice cut once and wasted my time with leakdown. -
Nobody was disrespected I even said I was grateful for him helping me out, but it still resulted in wrong bowl. My drain screw was stripped on my old bowl and we swapped a spare he had which apparently was wrong. He's a great dude. This choke is hopefully the issue. People hating on me for no reason. I never said anything negative or name blamed... -
I never threw anyone under the bus, I said I was helped. Who is starting stuff over this lol. The drain screw was stripped in my old bowl so we swapped another spare he had and it was obviously the wrong one, no blame no shame guys. Since they made starting fluid with top end lubricant? I only used it twice to experiment. Other avenue is to start all over. -
Well see if the carbs help If not, another avenue will be pursued. -
I greatly appreciate your response. Thank you for being polite in explaining as well. If there was an airleak, it generally would be from cylinder to reed, reed to boot, or boot to carb correct? Or worst and most unusually, a crank seal correct? It almost seems as though the car metaphor would point to the carbs as the battery and the airleak as pulling the heads...Not being disrespectful at all sheerider11 just wondering the Banshee thought process. I believe that the choke circuit would be the battery per say to check first in this case as it is most likely the root cause of the issue. -
I actually had a member of this forum stop by to help out with the carbs originally which resulted in the swapped bowl, not complaining because he helped fix the leaking bowl, just stating. I am waiting on the other set to ship to me to throw it on and run and in the meantime I have been running my thoughts through this forum. It seems as though everyone is so fast to jump on compression and leakdown, that when you actually pass the tests, there are no other thoughts or contributions...like those tests are a cop out of some sort. -
Lol because I am running through my thoughts to see if anybody wants to weigh in on them? This Banshee just may drive me to the point of self converstaion. lol -
I'm just trying to be the most educated Yamaha Banshee mechanic I can before just throwing money at the machine. -
Bought two stock carbs for $70 shipped from Power_Man... Thats the remedy. Nobody is willing to part with bowls, or at least I gave up looking and jumped on these stockers....Sound like a good plan of action TrickedCarbine? -
Just wondering whats so funny? -
They have been switched though. 2 right bowls have been swapped in. TORS Deleted, took forever to start or only on starting fluid. Left cyl ran lean, I'm thinking it has to do with 2 right bowls on the carbs. For anyone making fun of starter jets, that is the reason the bowls are choke side and non choke side specific...There is a jet that resides in the choke side bowl that is part of the choke circuit... -
Look it up in the service manual....referred to as "starter jet"... -
It is the starter jet that was swapped into the wrong bowl. The whole reason my crap wasn't starting and left cylinder misfiring was because of non-chokeside bowl being swapped to choke side body...Was wondering and wondering why the jet wouldn't thread in there..... -
Anybody have any stock intake boot fitting carbs for sale out there?
It is also listed on the choke circuit diagram in the banshee service manual, but the schematics don't even list the ot 1.4mm choke/starter jet....wtf am I missing here. aside from proper carburetion? LOL -
Maybe try to just throw bowl back on carb and fire her up without a rogue jet floating in bowl? Why is it so hit or miss when discussing these starter jets on Banshees...?? Some people swear there is no such thing and you cannot find it in the schematics from Yamaha, yet banshee service manuals list them in the parts list on carb....??? Any input guys?
