03banshee88
Everything posted by 03banshee88
  1. Still available Sent from my iPhone using Tapatalk
  2. Text me at 4438752683
  3. Decent condition pipes. 175$ buyer pay half shipping
  4. Can you send pics of case with crank to 4438752683
  5. I have some fmf powercore 2's for 200 shipped
  6. What would you be looking to trade for ?
  7. Also Athena 392 big bore kit right cylinder is bad though Sent from my iPhone using Tapatalk
  8. Fmf powercore 2 pipes - 300 Trinity 2-1 carb setup - 150 Pro design uni air filter setup- 80 only been on for one ride Some other stock parts once I start tearing it down as well. 4438752683 Sent from my iPhone using Tapatalk
  9. Only thing I did notice but don't know if that's what going to do that is one of the o rings that goes in under the fiber was broken but the little piece that was broken still went in under the fiber Sent from my iPhone using Tapatalk
  10. Yup Sent from my iPhone using Tapatalk
  11. The clutch lever feels good also I can't figure it out Sent from my iPhone using Tapatalk
  12. Yes I had the arrow lined up to the arrow. I also put one of the thrust washers in the one between outer and inner basket because it did not have one when I bought the 4 wheeler so it was making a knocking noise that's why all this happened but what makes it weird is because the clutch worked before I tore it apart and added the other thrust washer and lock washer that was torn up Sent from my iPhone using Tapatalk
  13. Yes Sent from my iPhone using Tapatalk
  14. The lock washer for the clutch basket. And yes I did. Sent from my iPhone using Tapatalk
  15. Do you have any suggestions I could take a look at Sent from my iPhone using Tapatalk
  16. I did the spacing with the steel plates going around I adjusted the clutch with the arrows on the case. I don't know what else I could have done Sent from my iPhone using Tapatalk
  17. I had the arrow on the pressure plate lined up with arrow on inner hub Sent from my iPhone using Tapatalk
  18. What do you mean as far as moving the pressure plate one bolt hole over Sent from my iPhone using Tapatalk
  19. https://vimeo.com/135819693 So the clutch did work but I had to replace a washer on the basket so took the clutch out. Just put everything back and it's doing this in every gear is the clutch shot Sent from my iPhone using Tapatalk
  20. What's your paypal I would like to order one? Sent from my iPhone using Tapatalk
  21. So it has a 170 main jet and a 55 pilot jet and it seems to have stock reeds still in it as well. Doesn't that jetting seem kind of low for it being a big bore with all the other add ons Sent from my iPhone using Tapatalk
  22. No I haven't taken off the the pressure plate yet ran out of time going to do that tonight. From what I've been reading it's either the basket bushing is shot, or the nut has come loose. From what I read and can see. Sent from my iPhone using Tapatalk
  23. Clutch side of the motor was making a noise only when I let the clutch out. So I pulled cover and this is what I got. Is this play normal in the baskethttps://vimeo.com/134902241 Sent from my iPhone using Tapatalk
  24. It's a keihin pwk how can you determine what size though I haven't found any markings on it Sent from my iPhone using Tapatalk
