brianault22.ba
Everything posted by brianault22.ba
  1. I sent it to a guy that knowledgeable in that Sent from my VS985 4G using Tapatalk
  2. Does it appear to run richer than the other side. Also if you put your hands behind your pipes does it feel like the same pressure is coming out of not exhaust Sent from my VS985 4G using Tapatalk
  3. Now I know my slides aren't sticking. Whenever my banshee runs it has oil link of squirting out the right exhaust. So I think it a bad crank seal. Do I have to split my case. Also lastly after warm up my banshee wants to rev up and kind of like the throttle stocks my father and I checked there is no air leak and slides aren't sticking. Can u help please!!! Sent from my VS985 4G using Tapatalk
  4. Cuts are toward back I'm if its sticking when I get home I'll check and let's pray its not a air leak Sent from my VS985 4G using Tapatalk
  5. I don't think so Sent from my VS985 4G using Tapatalk
  6. After I rev it. It almost sounds like its sticking Sent from my VS985 4G using Tapatalk
  7. It idled and runs good then out of no where it revs high Sent from my VS985 4G using Tapatalk
  8. I've cleaned my slides got all the carbon off and have no air leaks, but yet it still wants to rev high Sent from my VS985 4G using Tapatalk
  9. Or should I get idle screws Sent from my VS985 4G using Tapatalk
  10. Use the old cable because I think that the slides needed cleaned and maybe they got stuck Sent from my VS985 4G using Tapatalk
  11. So what should I do Sent from my VS985 4G using Tapatalk
  12. No Sent from my VS985 4G using Tapatalk
  13. They don't slam shut but there are air/ fuel mix screws but I'm sure about idle screws and is I hold throttle a 1/8 throttle and up it will idle but when it goes below it will die Sent from my VS985 4G using Tapatalk
  14. I've cleaned carbs and filter it feels like the new throttle cable has to much slack Sent from my VS985 4G using Tapatalk
  15. Yes slides put on and synced Sent from my VS985 4G using Tapatalk
  16. I have a 2001 banshee and when I bought it it ran great than recently it just started to go full throttle on me. I looked at the top of the carbs(wothout tors) and the throttle cable boots were broken. So I decided to replace the throttle cable and I've adjusted everything it runs great until I put it at 1/8 throttle then is dies. The old cable never had that problem and idled fine but would stick. Sent from my VS985 4G using Tapatalk
