Deuczwild
Everything posted by Deuczwild
  1. just found a brand new set from local dealer thanks for the input.
  2. If their in decent shape. Trying to get my cheetah rebuilt without braking the bank.
  3. not yet was gonna see what I get off here
  4. Looking for a set of 68.50mm pistons
  5. yea I've read this one a couple of times now
  6. You know strm trpr I would send it out but shipping would be to much I've been doing my own work on snowmobiles last ten plus years or so. So I think I can handle it I do have a Clymer on hand and I just eyeball carbs been doing it on snowmobiles never had any problems.
  7. awesome thanks, now I just have to find a couple of pistons to rebuild and then ill be able to fly round the trails.
  8. Yea that's what I been reading I figured it was bout a 392 or something with the 68.5mm bore and 54mm stroke the guy I bought it from thought it was a 421 but after doing some reading I think its a 392 or something which is bout right.
  9. yea I did that and it measured round 5.4 cm which would be 54mm but I still have to tear it apart regardless.
  10. I believe its a stock 54mm stroke when I tear into it ill know for sure.
  11. Hi, first off want to say awesome site, gave me a lot of info on some different things. Recently bought a banshee, had some problems, boiled down to having 90 psi on both, want to do rebuild but not sure what size motor I have. I know its power valve cheetah. But not sure what size? On top of my dome it says cheetah 68.5 - 21 - 10. Any and all info would be surely appreciated. Thanks
  12. 1) What type of aftermarket exhaust do you have? FMF 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all CUSTOM 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) round 150ft above sea level 5) What size pilot jets are you using? 48 6) What size main jets are you using? 145 7) What temperature is your Banshee jetted for? 8) Do you have a port job? 421 cheetah P.V 9) What kind of carbs? Keihen 10) What size carbs? Pj 34mm
