Jessy
Recent Profile Visitors
524 profile views
Jessy's Achievements
  1. 52-55 pilot, 155-60 main 👍
  2. Try Martin at Mad Biker Designs he will help you out. Jess [/url]
  3. Thanks, do you have a link to one or which dealer? Thanks Jess
  4. They are new pistons, clearance on the box was 0.10mm, clearance at the bottom of the skirt is 0.10mm at the top of the stroke nearly 0.5mm due to the piston taper????? Are there any other options for the 73.5mm pistons? Apart from the Wiseco Thanks Jess
  5. Hi I've recently had my 492 cheetah replated/new Pistons (73.5mm), I went with 0.10mm clearance and it rattles like hell. I measured the Pistons and they are around .4mm larger at the top to the bottom, currently running Wiscos. The rattle is that bad it feels little the skirts are about to break. Are there any other Pistons out there that run may be tighter tolerances... Thanks Jess
  6. Hi What's the recommended piston bore clearance for a cheetah 485 with Wiseco's. Thanks Jess
