Pun242
Everything posted by Pun242
  1. Nope! If the clutch basket is out and I shift it into gear the tires should still lock up right?
  2. Well the plate has 3 arrows on it I'm sure I lined it up correct. But would that be the case why it's not taking a gear. Meaning the tires are just moving freely
  3. I recently bought a 2006 banshee when I got it it was running fine but wasn't shifting properly. I took the clutch side casing off and found that the shift shaft adjustment screw was broken. I replaced the screw nut and lock washer. When I installed the clutch basket and the plates back on correctly and tighten everything down to the right specs. Today when I put the banshee in gear the its Iike its in neutral! I can see the star moving and shifting correctly but it's like it's just in neutral. I know that when you have a bike in gear and you don't sink the clutch the bike wouldn't move! So I really don't kno what the problem is. A friend said that it might be the drive shaft not linning up or it could be snapped!
