Larita09
Everything posted by Larita09
  1. I need some cranck cases mine cracked and a idler gear as well
  2. Seems best bet is to leave alone til I get the screws, plus my carbs are in sync so I'll leave them as is my bike doesn't see much idle but at warm up.. Thanks for the replies
  3. Got a banshee and works fine but the problem I'm having is that it has the TORS eliminator kit without the idle screws so it obviously won't idle unless I pull out the throttle cable at the handle bars. I ordered the screws but was wondering if I do any harm or performance issues if i set it to idle by the thumb throttle adjuster until I get the screws in.
  4. 1) What type of aftermarket exhaust do you have? Pro Circuit 304s 2) What type of airfilter do you have? K&N pods 3) no air box 4) What is your elevation? 3500 5) What size pilot jets are you using? 30 6) What size main jets are you using? 300 7) What temperature is your Banshee jetted for? 70- 100C 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? 26mm
  5. Yes where the petals meet the ends of the reed cage
  6. Might be reeds not sealing right.. It will run but hard to start when this happens
  7. Looking to get some SB inframe shearers since I have pro circuit 304s and want more top end. Don't mind buying used in good shape or if some one knows of a good deal from a site sponsor
  8. Would u consider selling? What dents are on them?
  9. 22x11x10 10 paddle seems a little too much for a stock she, well at least to me it does.. Anyways why don't you try playing around with the gearing first
  10. No longer need, Thanks
  11. Contact me on here... I've been getting some scam txts to my phone
  12. Larita09
    A-Arm and axle
    Looking for oem right upper A-Arm and rear axle. Txt 9152585039 Thanks.
