lowrider136
lowrider136's Achievements
  1. Well I had the slides in wrong lol what an amateur. ...this banshee stuff is all new....bike runs like a champ now!!!
  2. Think you guys may be right about some sort of air leak
  3. My bike will not start. ...we decided to try and pull start it and it would run but it ran terrible and would not stay running ,almost like it was at half power. I recently replaced reeds and cleaned carbs. .it fired up one time and stalled out and wouldn't start again, we even used a little starting fluid. ..this bike has a fairly new top end and have never had an issue since I replaced reed valves. ..now when it did run it seemed like it would take its good old time reving down, almost like the slides were sticking but I assure u they are in good working order.
  4. What is a leak down?
  5. Ok guys got a 2000 banshee runs great had to replace reed valves (v force 2) and i put a chariot throttle on...took it out and the throttle was sticking. Now i looked threw airbox and didn't see the slides sticking but I noticed that it revs back to idle very slowly? Do the caps and slides go back on the left n right carbs? I did notice the right carb slide was slightly harder to get in than the left but I don't see them sticking....they are both very close to being in sync.... I'm at a loss with this.... any suggestions? Maybe I have the tops and slides switched? And also the cable is very easy to pull out of the carb which pulls the slide...shouldn't those be kinda hard to pull out?
