marcobdm
marcobdm's Achievements
  1. Ive tried swapping +/- ...also yanked the harness just to doube/triple check continuity...stock flywheel n stator. Pickup gap @ .016 in ...im going to check the flywheel again because the flywheel key did pop outa place a few times apon installation of the new crank...i cant visually see it being off the key it doesnt spin or anything but at this point its double/triple check everything....and thanks for all the second opinions too guys! #bansheehq
  2. Yup parking brake wire is good too
  3. Disconnected tors shit already didnt help...not sure bout parking brake but never gave me problems before
  4. Aint stator either!!!! Im ready to put this p.o.s on craigslist for fuck sake
  5. Its a fucking ghost alright...im clueless
  6. Yup have power to coil. I swapped out th coil from buddies shee and still no spark so i took the caps off and touched the wire to my finger and kicked it over n got shocked enough to tickle my fingertip yet nothing when i have caps n plugs in...new caps to so thats not it either
  7. Cleaned connections as well still nothing
  8. yup cleaned the ground by the voltage reg and cleaned the coil and coil mount still no spark..im lost!
  9. Tried swapping cdi with buddies shee and mine still has no spark...wtf is wrong here??
  10. Coil is now working replaced spark plug caps read 15k ohms reading cap to cap but it still wont fire?? help please
  11. Also pickup coil is good. And when i tested the ignition coil with my dvom it didnt read anything from the spark plug wires or the little tabs the orange and black wires connect onto
  12. Ok so i tested everything wire harness is good switches are good and no i didnt remove any switches...stator is good also..took ignition coil to local shop they bench tested it and said right wire sparked fine but left wire didnt spark so well and last time it ran (2 years ago) the left pipe smoked less than the right...is the coil just shit from sitting overtime? and why do i not have spark?!
  13. Well sadly like it says my shee blew up:( but whats even more sad is it blew up having spark...now that i rebuilt it top n bottom end...no spark..and im not sure why? Any help is greatly appreciated.
