dags113
Everything posted by dags113
  1. 1) What type of aftermarket exhaust do you have? Pro circuit 2) What type of airfilter do you have? Pro Design Foam filter with intake flange 3) Are you running a)Stock box with lid on,holes drilled in top 4) What is your elevation? 160-190ft(Adelaide-Australia) 5) What size pilot jets are you using? 25.0 6) What size main jets are you using? 270 7) What temperature is your Banshee jetted for?22-28* C 8) Do you have a port job? no 9) What kind of carbs? Stock 10) What size carbs? 26MM I just purchased this bike and it was really smokey on initial start up.but cleared up after warming up.i have only ridden up the street and back then parked it. So i have drained fuel,(which was old)cleaned out carbies,airbox,filter,Changed plugs,decarboned exhausts and is now ready to fire up but just wanted to check specs first. It also has a boost bottle,pilot air screw wound out 2 turns from hard seated,5n7 needle on #3 setting. thanx
