323Racing
Everything posted by 323Racing
  1. Already did, only see one collar. Thats why I'm so confused as to where this other collar goes.
  2. Hi I'm trying to install my new swing arm and the upper linkage bolt is too long. Is this normal? Should I just use washers? Thanks
  3. Hi I am trying to figure out how to put back my steering stem. When I removed it, a collar fell out and there is also another one in the frame with the bearing. I have 2 collar spacers one washer one nut and one cotter pin So what I'm asking is how and what order do these parts get assembled? Please help! Thanks
  4. Should be making some power. Pro Design 22cc chambers .50 over vitos superstock pistons VForce 4 reeds Jetted carb FMF Fattys with FMF power core 2 silencers K&N air filter kit with airbox and lid At sea level 93 Octane 32:1 Maxima Castor 927 Maxima MTL 75w
  5. Ok so after driving my banshee for the first time I love it! BUT I have a few problems I want to fix before I paint my frame. It is pretty much impossible to get it into neutral while its running Shifting gears is hard, you really have to force it into gear and I have a slight bog right off idle, other than that it runs amazing I heard about the pancake bearing, is this worth it? Probably going to get a new impeller and oversized radiator. Mods are .50 over vitos pistons, 22cc pro design cool head, vforce4 reeds, k&n filter kit with airbox and cover, and jetted carb. Thank!
  6. Thanks what about the idle/air screw? Start with 2 turns out?
  7. YFZ350SPV Means what? YFZ350SEV Special edition?
  8. Deadbeat I thought it was 14.1hp.......Also does the nose of all OEM banshee plastics have the yamaha badge on it?
  9. The numbers match the frame. The rad cover has the carbon fiber look and 50th badge. I'm so confused
  10. Hi I need to jet my carbs but I wanted a good place to start. .50 over pistons Pro Design Cool Head 22cc domes FMF Fattys Powercore 2 Sea Level Stock airbox with lid and filter Vforce 4 reeds What jets will get me close to where it needs to be? Thanks
  11. Just took the head off it has 22cc domes and .50 over pistons
  12. I just bought a 2006 banshee 50th anniversary edition. On the title it says YFZ350SPV. The banshee is black with gray frame and this is how it came brand new off the showroom he showed me pics. Is this right? Isn't it the yellow one? Please help Thanks.
  13. Hi I'm new here and just bought my first banshee. Its in rough shape but has a brand new top end. The top end was never started. I did a compression test with the carbs, reeds and exhaust off (no? I had it apart already). The left side was 135psi and right was 127psi. It has a pro design cool head but I don't know what cc the domes are and .30 over pistons. Does this sound ok? Thanks!
