Giersi Garcia Vega
Everything posted by Giersi Garcia Vega
  1. When i do comprecion test it gest only to 95psi both side
  2. I put new reeds new carbs and new piston and rings could it be the cylinder
  3. My left side is getting to hot why and backfiring leftside
  4. Yes i bought the same size and put all new gasket
  5. I bought the same that i had before
  6. Hi im new in here i have a 2004 banshee and lately if gives me alot of troubles first the stator when out i buyed a new one after that the real problems began the left side was backfiring And overheating throwing flames wen i hit full throttle and it was runing like shit i checked the compresión i crank and nider of the cilinder where pasing 100 psi so i bought 2 brand namura stock pistons and put it back together and did the compresión test again and even with the new position it didint pass 100psi I put it to run and still do the same overheat and backfire lefside only I barow 2 carbs from my friend and it began run good but still to heat on the left side Saturday i was going to the drags and out of no where it start to backfire again and it burned the front lights when i rev it i put new one they were good wen i went to the drag on the second pass it burn the lights again i run 9.70 then 9.40 can somebody giveme any ideas stock banshee only trinity pipes
