karab32
Everything posted by karab32
  1. Clean carb every thing seems fine for now
  2. Hi guys i noticed when i hit water or when i wash my banshee throttle are sticking but i can play with the wire... so wire dont jam i lubricated it still sticking..... I run stock air box and cover with k&n filter i have a hole saw in the top of the airbox cover to let it breath I have tors eleminator kit. I cannot also find any water in air box...... Anybody have the same problem? Any advice, solution? Thank's
  3. Hey another question i made a big run with it and i had a lot of fun.... So i wash my banshee... and make it run at idle. This morning i arrived go for a run, trouble came back trottle was sticking again, so now im wondering if it is because water. So any advice?
  4. So i polish slide and carb body ! Everything works fine no more trouble Thank you guys for the advice
  5. Fine !! Thank you alot
  6. thank you guys gonna try every thing, i'll give you some news !
  7. I mean that the tapped screw are not adjust the same way in the 2 carb So i want to know if its important that the screw in the carb have to be adjust exactly the same? In the 2 carb or if it doesnt matter ?
  8. Hello, guys just wondering how do i adjust the new tapped air screw. I noticed that the one on my new banshee werent adjust the same way on the carburetors is it normal ? There is one more screwed than the other just wondering thank you
  9. ok im going to look for that thank you
  10. Ok i'll try this do you beveled it alot? Cause i did it with sandpaper a little and it doesnt seem to change anything. Yes i oiled my cable recently. There is no strip on any adjustement I will check for the spring. And what pin do you mean? do you mean the jet needle ? thank you
  11. Hello, im a new members ! Just bought a banshee recently and everything was going fine tried it was running fine. one morning, i decided to go for a run and it was running prettry weird throttle was kinda sticking it was also throwing gas at every place possible. So i dissasemble, clean the carb, adjust pilot air screws, also synchronize the slide. i also checked if there was any airleak. I noticed my KN filter had to much oil so i cleaned it and i also notice a little piece of wood in the vforce so i inspect them eveything was fine. Motor have very good compression. i changed the carburetor gasket. Yesterday, tried to go for a run same problem so i retire air box open carb again everything was fine. while i was reassembling i noticed without air box that one of the slide was sticking like 2-3 mm higher than the other(the left one) I also realised that my caburetor slide on the left side was kinda used. the slide is completely or almost grey metal there isnt paint anymore on the right one there is more paint. i decided to buff it a little but is didnt do anything same problem. I also called yamaha dealer and the slide are kinda expansive. so now im asking if there is a solution carburator are very good and clean the wire is brand new but still sticking. i wondering if i can paint them with something or i dont know.. someone have any sugestion thank you !
