Russell Wealthall
Russell Wealthall's Achievements
  1. Run more transfer and it gave a big hit more with good bottom end Also ran dial a jet and got a noticeable mileage increase had to bore carbs bigger to offset tube restriction
  2. One off my sons runs a athena 25 pilot toomeys needle 360 main on his t5 Toomeys high flow foam on stock cage( flows the same as k&n holes in airbox Runs perfect plug colour But tranfers are way to low no bottom end Took 40 thou off the bottom to bring the power on sooner which it did but the transfere then measured 109 degrees to ex 188 Ridiculous raising them up to 128/130 ish Good transfere area good inlet size good tripple port ex Hits really hard but only cause thre ain't no bottom or low mid no matter jetting or timing
  3. Tried 24 cc domes hurt the revs Also 168 main 45 pilot
  4. I'm runnin pro cuircuit for trail and it'll lift 6 th gear wheelies on limestone tracks no worries only a421 with 35 mm and 26 cc domes at 4 degrees heavily mod airbox with toomeys foam filter standard gearing I'm happy with that would mind trying the drag pipes but until them it's all good
  5. My son bought em after he smoked his stock pistons I put them on t5 open box jet 360 ran like a cut snake high revs absolutely no bottom or bottom mid jetting was perfect Pulled off head checked durations ex 189/109 38.5 blowdown couldn't believe it Just about to bump up transfere to 127 then it should be good Inlet good size Trans good size and shape unrestricted and tripple port ex why the hell the Trans was so low I can't imagine
  6. Seen a mint set on a wall full set complete with stickers wants $650 aust for them newly bought them for mine Mine are mint now so I didn't get em If your interested your gonna have to find out about post prices Also I'd have to see if there STM there they were 2 days ago
  7. The choke points in the updraft close to the Center divider dosnt follow contour of cylinder but flattens out this is the upside wall but can be hogged out 3mm to then get a nice mirrow curve of the liner it helps un chock and stops curve change before exiting my 1cent
  8. I run 25 pilot toomeys needle 4 th clip dwn 340 main with toomey high flow foam with numerous holes I n box and lid that flows same as my k&n V4 round the package comes on straight aftter idle and pulls the front wheels up in forth under power only Stock stroke and ports Sea level and 21 cc domes 4degrees ignition Have pc on 421 serval as well that's another story 5th gear wheelies comes up with a snap 6 th gear comes up 6 inch 35 pkw 48/168 same air cleaner setup and timing 26 cc gives 132 psi Ran 24 cc but revs suffered
  9. Trying to get a contact address for Camatv to get my gears cut for fast changes for trail type riding that can be back loaded already running CFO cut out button on bars that works pretty good but it's mechanical button and will keep wearing out I suppose got the cases split now so I could send it over from Australia but I can't find an address Please help
