nitenite
Everything posted by nitenite
  1. Ok will do
  2. Will do 1st thing n morning and will let u knw what happens. Thanks a lot u guys rock!
  3. Also I have a 410 Athena kit for it but needs sleeved. How much would that b worth if I want to sell it?
  4. There was a 260 in it but I took it out n put 280 in. When I got it.. at high rpm or at a high gear it would bog down and sputter. After new main jet that doesnt happen anymore but now it bogs n low rpm range. I can pull clutch get to mid rpm and it's fine. But role out n 1st it acts as if it dnt wanna go. Then bam! It lifts the wheels n takes off.
  5. Well previous owner told me to run 53:1 as directed by bottle. But that seemed pretty damn thin. And will it b ok to change ratio. Buddy told me after I rebuild carb to stay with whatever ratio I go to. N I lied it's about 20-25℉ lol
  6. Ran it today.. and smokes when u first start it then goes away... Bogged going Into 1st but after that. It rips. Seems like at 1/4 throttle is when it Boggs at 3/4 or full it takes off
  7. Vforce3 reeds..fmf pipes and silencers, k&n filter, wiseco pistons .20over..stock box with snorkle.. 280main not sure pilot. Tors Elim twist throttle. Running golden spectro at 50:1 needle position is 4th. I'm n Ohio n the flat land no altitude
  8. Just put it on... Kicked it and fired right up! Boggs dwn n 1st.. no smoke at all! Lean? It's is also 15℉ outside to so....
  9. It was off! Now I'm gonna try to kick it ovr n c what happens
  10. Ahhhh gotcha goin to go check now. Now would this allow it to not start on it's own also?
  11. What exactly am I look for with choke tube? Do they go bad? Sorry 1st time ever doing the work myself so I'm clueless lol
  12. Hey.. new to the site.. great info.. anyways... . Have a 02 shee. Before carb rebuild bike started , idled but top end would bogg out n putt. Since I rebuilt carb... #1 bike won't start without a starting aid (starter fluid,carb cleaner etc) once started it will not run without choke on. Tried warming it up etc etc still nothing. As soon as I put choke in it dies 30secs later. HELP me! Tryin to get ready for the season!
