the jets are both new on the mains and the needles are new as well. plugs are tight and it is still running the stock coil so the plugs have the screw on the top of them. it seems to run ok down low and in mid but when it gets the rpm up and you are in it hard it is like it hits a brick wall and just doesn't pull. both cylinders are firing good at idle and the right side seems to have a little more pop to the exhaust at idle then the left. I am thinking coil/wires as well
