Creilly2106
Everything posted by Creilly2106
  1. It's was coil pack tryed my buddy fired right up !!
  2. Checked compression today 119 each cyclinder
  3. Going to do compression test tommorow
  4. Compression test-no Keyswitch-yes Wires cut at throttle Have wires cut at handlebars( e-brake) Cleaned carb Tryed another CDI Tryed pluggin tors back in still nothing just will start after 15-20 kicks but struggles to stay running n dies out lights all work when it runs for that 5-10 seconds before stalling
  5. Ok going to have to find stock one any idea why she won't run right or start normal now ? Well any suggestions
  6. What can happen to motor with that installed sorry to be pain lol
  7. You have any ideas what can be causing this problem I'm having ?
  8. 93 32:1 fuel also
  9. It's +5 timing and I did unplug it still nothing I have the delete and I have brake wires cut it just when I plug it in while it was running it just died and then I unplugged and try to start it back up has hesitation trying to stay idle n just dies can rev it but takes a good 15-20 kicks to try to get it to even try to start up
  10. My set up is v-force 4 reeds,35mm 2-1kelhin carb, uni air filter, cool head,advanced timming key for crank and adjustable timming plate set at +5 for stator ,TORS Delete was running fine then I had it running fine n strong!!! then plugged in tors clip just being curious n it just shut off then I tried kicking it won't start I can get it to start maybe after 15 kicks then it just hesitate to stay running and barely revs up then just shuts off
