smhayden350
smhayden350's Achievements
  1. Hey fellas. Needing a little info on some larger cylinders. What would be good to use. And would like to know some different setups that can be used and that run well. Thanx Matt
  2. I just finished painting my banshee with a rattle can . All you need Is some 80 grit sand paper and I bought some dupli color acrylic enamel paint and some enamel clear coat and it looks just ad good as a powdercoatng would. Hope this helps
  3. Well I'm wanting to trail and drag with the same tranny .
  4. Needing a little info on override transmissions . I'd like to know what exactly it is. the pros and cons . how reliable and how they preform . Thanx matt
  5. Hey fellas I recently bought a few new parts for my stock cylinder banshee. In total it now has a 68mm bore,4mil crank, v force 3 reeds, 34mm pwk alky carbs. +8 swingarm, cpi drag pipes, spiked tires, and a drag n ported head. I was just curious to know how this would compare to other banshees and if y'all had any tips n tricks for this bike. Thanx matt
