liass44
Everything posted by liass44
  1. http://easttexas.craigslist.org/sno/4262008962.html
  2. Ok thanks, I already replaced the oring about 1 week ago started it up and it was still leaking so I guess I'll put some sealant on the threads thanks.
  3. It seems there is coolant leaking from the allen screws on the joint that attaches to the head (coolhead). What should I do to fix this, should I use some type of sealant on the threads and if so what type? Thanks
  4. Yeah if you painted your frame you may have a bad ground.
  5. You need a torque wrench. You can usually find one at your local autoparts store. Make sure you get one in ft-lbs if you do.
