mfritz23
About mfritz23
  • Birthday 04/06/1986
    harrison michigan
Contact Methods
mfritz23's Achievements
  1. so 150 should definetly be ok then? what coolant did u switch to vulva fan?
  2. got my banshee last fall and didn't ride it much but anyways the temp the other day was anywhere from 130-150 is this ok and whats a temp to shut her down at and the outside temp was only 60 degrees thanks its a 4mil stroker bored .40 over if that makes any difference
  3. thanks guys for the help
  4. Was looking to buy first compression tester and a leakdown tester to have in the garage for when needed and such was curious to what brand to buy or if the cheap ones are fine was just glancing on ebay any info would be appreciated thanks
  5. thanks guys one more dumb question is the round style the way to go I mostly trail ride a lil drag race here an there was thinking of getting a +4 swingarm anyways
  6. thanks starwriter is the roundhouse easy to install ive never seen one in person just online
  7. today I was cleaning my chain and putting some chain wax and noticed a high squeal sounded like from the axle carrier it is a stock one with no grease fitting is this a indication for bad bearings? If so I was thinking of putting a whole new axle carrier in with twin row bearings good idea? bad idea? thanks any help is greatly appreciated
  8. just went and double checked my tors is removed they just left the wires in the thumb throttle part thanks oldskool
  9. ok thanks will check them out bought quad this summer has a lot of work done to it figured tors was removed already lol is it hard to delete it
  10. my throttle cable broke and need a new one just asking u guys best one to buy was just browsing ebay figured I would get some opinions carbs are keihin 33mm thanks also looking at getting a new extended throttle lever what do u recommend last question was looking at my thumb part and noticed electrical wires run into like a little switch inside there what is that and does aftermarket extended throttles accept that piece or what thanks for the help and have a good xmas.
  11. thanks guys!
  12. hi im mike new to bansheehq I just bought my first banshee it has a lot of mods done and was built by f.a.s.t racing I was wondering how to tell if it has a different timing plate or they advanced the stock one guy I bought it from never mentioned also when someone says +4 domes what cc would it be just curious questions appreciate it thanks
