charlie__walsh
Everything posted by charlie__walsh
  1. how much for the seat and do you ship to canada? A1G1G5
  2. Lol thanks I wanna tackle it myself but have to see what happens! Carbs.. What is it about these pwk's? Should I read into these?
  3. Anyways.... The carbs any suggestions... Should I get new ones?
  4. Ya that's the plan so far I just like to have an idea before some tells me it's totally gone and it's just a piston... New with the banshee and I no there different ... Just trying to cover all bases...
  5. Figured... Can you get complete kits? Or best route?
  6. Bike was just bought from a buddy ... No maintenance done.. He done tors removal and wasn't running right sence ... Fixed it but I don't no ... Then this... It was 120psi when I bought it... Don't no about filter... I wanna no what to do with the carbs to ... Should I just take them somewere to get fixed I want this bike back to normal...
  7. Engine... Not axle ... Kick starter won't budge ... I no it's gone just wondering if that means bottom end foreshore..
  8. I took my bike out and was driving along at about 50 and it started to knock and died .. I kicked her over and that was it ... Kicks tarter wouldn't budge.. So do that mean it's the bottom end... If so is it worth it to do it ureself or just a hassle..? Thanks guys .. Now I no why you say they are money pits!
  9. Sorry must watch my words ... I meant port n polish...
  10. Finally some people that no what there talking about ... I'm starting my rebuild soon and I wanna have everythin before I start.. I don't want to fancy ... But if I do the polish is there anything else I need to do...
  11. sorry very eiger to drive my new toy... had to learn how these forums worked..
  12. thanks guys great info... exspecially about the boreing.. but how do you up ure cc's I thought it was boring... and iver herd about a single carb setup? is it useless?
  13. Hello I have a 04 shee and my right carb slide is sticking, so I poped the seat and filter to have a look and sure enough it was coming down slowly and sometimes would stay open, as soon as I turned the key the carb slide would drop completely.... just wondering the best fix... can I stretch the spring out?
  14. I'm lookin for a good setup , I'm thinking of a bigger bore but not to much... Is it worth it or just keep stock...? Next question I'm looking to do paint my frame... Want durable... Advice?
  15. Perfect ! I'll try that ...
  16. Yes I have idle screws installed... It's all stock my pilot is at 2 turn... The mains are stock...And my needle is on the third notch... Would the needle setting effect it? I put it all to stock the needle was on 4...
  17. The settings are normal... 3rd notch stock mains and 2 turns on pilot... What's way do you set your idle and sliders correctly...I really don't wanna do damage...
  18. I don't I'm a new bus there anyway to get it?
  19. Lol I actually figured out all about it yesterday... Now I'm trying to adjust idle and needles...
  20. I just fixed my carbs they were really messed ... I have tors removed I have all connections and setting in carb correct ... I'm wondering if there's a certain way to adjust your idle ... My choke just floods engine...and dies...
  21. Well they should hit the bottom... Try switching sliders... That was my Main problem.. It ran really rich and would run extremely high... When I put them in right it started first try and revved and idled perfect...
  22. Did you check the stuff ? The idle screw should be fine at 1.5 to 2 turns... It's something else?
  23. Just dealing with the same problem , is the tors carberator still on them..,? If not your idle screws might need to be filed down... So that they hit the slider.... And make sure ure sliders aren't switched... They should close all the way
