ore rider
ore rider's Achievements
  1. stodderdshee, in post 16 you mentioned that you have the "T" fitting in you're gas line installed so that perpendicular leg leads to the left carb while the straight through ends are connected to the petcock and the right carb. I would recommend changing it so that the perpendicular leg is connected to the petcock as your current setup may cause the left carb to receive less gas than the right carb. It wouldn't cost anything and would eliminate one more potential fuel issue once you get it all back together. Or you could just get a dual pingle petcock and be done with it.
