G3mend
Everything posted by G3mend
  1. Hello all i just rebuilt my top end and went to 65mm pistons. Im using stock carbs with 320 mains. I have an open air box with KN air filter and a porting job. When i bought the bike it screamed when it hit the power band. Problem was it was jetted with 280 mains and i was running to lean and blew gasket and kept overheating. At this point i decided to rebuild top end and go the next size up to 65mm. Put everyhting back together and everything seemed good. 125 psi on each cylinder. Broke it in using 15 minute heat cycles for a whole ank of gas never going above three quarter throttle. After the break in, when i went to hit it (accelerate hard) and feel that notorious banshee acceleration it just want their. Never really seemed to hit the power band. While i rode i kept checking the temp of the head on each cylinder using a infrared thermometer. The left cylinder seemed to top out at about 210" (fairly normal for hard riding i believe) and the right cylinder seemed to top out at about 175-180 degrees. It almost seems that the right cylinder isn't getting used to its full potential. I swapped the ignition coils to see if the problem moved to the other cylinder but it did not. Any help will be appreciated. PS i tried 320 and 330 mains and the same thing
  2. can anyone help. lost my power band after top end rebuild
    1. Show previous comments  1 more
    2. Surfrjag
      Surfrjag
      Check dryer.. thats where i lost mine
    3. Hazzard Racing Customs
      What did u rebuild with ???
    4. wycked68
      wycked68
      try green one! that one really works!
