animal1000rr
Everything posted by animal1000rr
  1. ^ as he said?
  2. I'll take the timing plate what's your PayPal address? Sent from my iPhone using Tapatalk
  3. Did these sell? Sent from my iPhone using Tapatalk
  4. That gives me more insight on my question. Thanks to all that answered and those that read and just put in some thought! Sent from my iPhone using Tapatalk
  5. and thanks for the input guys!
  6. 1/8 mile is the distance, so from the input so far there is a slight difference but the major difference is the setup after the combustion?
  7. I guess this question is geared more toward builders but all input is welcome. Is there a great difference in the porting and setup of a dirt drag as opposed to an asphalt engine? just cylinder and case setup, I know final drive setup is totally different.
  8. Please send me pics of the frame 337-319-2977 Sent from my iPhone using Tapatalk
  9. Are these still for sale ? If so send your PayPal info! Sent from my iPhone using Tapatalk
  10. Do you still have the carbs? Sent from my iPhone using Tapatalk
  11. Would the big bore domes work with cub Pistons? Sent from my iPhone using Tapatalk
  12. thanks sleeper, i have measured. the wheels with the rotor mounts are wider in the axle area. what i do see is the rotor mount is not machined with the wheel and was wondering if anyone knows how or has a way o remove them or if it can be done. registered user i appreciate the offer but i will pass. and a quick peek is the reason for the question.
  13. No one has any info?
  14. I have two sets of spindlemount wheels, one is stock taper and the other is 5/8 with rotor mounts. My question is, can the 5/8 set be converted to stock taper? And are the rotor mounts removable and reinstall able?
  15. Waiting on pics Sent from my iPhone using Tapatalk
  16. It's loud. At first I thought that it was the exhaust resonating but I have damped them and the noise was still there. After getting in very close the noise is coming from the stator cover. Sent from my iPhone using Tapatalk
  17. dibs on the 6 pack rack
  18. I have a noise that I think I have narrowed down to the flywheel. when I remove it and shake it I can hear something moving. Does this mean that it will fail soon or is it just something to deal with?
  19. Are you stating that you have Yamaha and Honda hubs?
  20. Please send pics of swing arm Sent from my iPhone using Tapatalk
  21. Wes does the lsr sprocket hub fit stock axles or do I need the lsr axle? Sent from my iPad using Tapatalk - now Free
  22. I bought a 10" stretched swingarm fom a member and it did not come with dust caps. The pivot tube is a smaller diameter than stock. Is there a place that I can purchase custom sized caps with the rubber seals?
