shook55
    02 vitos pistons .60 over dyno jet fmf sst fmf poercore 2
shook55's Achievements
  1. why wont they work
  2. so if i got standard travel shocks it wouldnt work
  3. ok i cant stand the stock shocks on my banshee and i was gonna put some used shocks on it from a yfz450 just wondering would longatravel shocks work on the stock aarms and what all would need customized to put yfz aarms on. thank you
  4. did that and it fixed thanks
  5. i took the flywheel off the stator poles had some rust i cleaned the rust off and it has the tors on but the wires are snipped i dont have any of the switchs hooked up the main key switch is snipped off what switchs do i need hooked up for it to make spark? i sanded the coil grounds down to the bare metal i cleaned the ground on the back by the voltage regulator. are there any othere grounds other than one on the stator that needs to be clean ?
  6. ok i bought a banshee that was blown up it probally sat for 3 years so i rebuilt it went to start is and no spark so i got a cdi box no spark got a coil and i can get a spark every now and then this thing has me stumped i cleaned the stator and the pick up and put the gap back in spec plz help
  7. banshee is making me maddddd!!!
