Matt22
    2006 Yamaha Banshee
Matt22's Achievements
  1. I've always wondered, what does that little bag do?
  2. Thanks for the help!
  3. Thanks, that worked reality easy. Once I put the slide in... How far is is suppose to sit in the carb? One is almost all the way down, the second is in but not as low, the throttle cable is longer on one as well?
  4. I recently changed the jetting on my banshee. When I took the top of the carb, I un did the two screws holding the spring and throttle cable to the slide.... Only problem is now I can't figure out how it goes back together. Does the spring sit under the brass or silver portion or just sit in there and stay due to pressure? Looking at it I've figured one screw pushes the bracket over to hold the throttle cable, but what's the proper way to put it back together? Any help?
